Kubota 1511 get diesel in the engine oil?
SC3 Cattle
We run 4 kubotas 2 are 1511, 1 of them has about 200hrs and just started getting diesel in the engine oil, was wondering if any body out there has had any issues of this happening?
Hammermechanicman
Check your lift pump. if you have an electric lift pump disregard. If you have a mechanical lift pump a small hole in the diaphragm can leak fuel into the engine but still work.
SC3 Cattle
It has an electric lift pump
