Kohler part compatibility
Freddie21
Hi Everyone, will the head assembly from a Kohler SV470-620 22hp fit a SV470-620 19hp? Are the valves and the bore the same. I have a TB Super Bronco 13BX60TG766 that threw a rod and I need the head, carb and starter from it to make a Cub Cadet 13AX11CH056 motor complete. Thanks for the help.
Need the Kohler Model and Spec numbers off both engines before we can answer that question.
Freddie21
Problem is the engine shroud and valve cover is missing from the CC 22hp motor. Unless stamped on the block somewhere, they're gone.
Well put it this way,
The bolt pattern will be the same so they will be able to be bolted together
The castings will be the same so if worst comes to worst you might need to swap the bolt on bits over .
