Are you nuts? 38 VDC will fry the PTO clutch in short order. IF you took the time to look-up the JD G15 you would have seen that the Kohler is using a rectifier/voltage regulator setup. The output DC voltage should be no more than 14.5 VDC.your mower has no battery, so your rectifier is changing ac directly to dc . so 38v is right. you dont have a regulator. your just powering the pto clutch
Sounds like the rectifier to me. Those change the spinning rotor/armature from AC to DC voltage. Voltage regulators keep that said voltage at a constant level (battery voltage). Sounds to me like battery voltage level is needed per StarTech.What is the reason for the 38V at the B+ leg of the rectifier? the spec for the PTO says that it is a 12V PT and works correctly, my voltmeter also works correctly
That engine is also used for the CV15S variation which has an electric starter and charges a 12V battery, the schematic for that engine shows a connection between leg B+ of the rectifier through the ignition switch to the battery for charging. Does it use a different stator or rectifier?I see none of you have worked on rectifier only systems that have no battery, that directly power ptos. 38v at no load, when pto is on it will drop to the proper range
