Aikaru
- Dec 17, 2021
- 1
- 4
I have had a surging issue on my motor for quite a long time now (About three years) and never paid much attention to it. When warm, the engine surges at mid to full throttle when idling but does NOT surge when at the lowest throttle position. However, when the PTO switch is engaged at full throttle, the surging immediately goes away and the engine smooths out.
When the engine is surging at idle, you can visually watch the governor constantly move with the sound of the surging as if it is what is making the engine surge.
I have performed a complete electrical system reboot which did nothing. I have done an oil change, a spark plug change, a fuel filter change, and an air filter change and the surging has not gone away.
I have also checked for any vacuum leaks and there are none.
Could the ECV system be out of wack?
Thank you.
Thank you.
