primerbulb120
Moderator
- Nov 3, 2014
- 43
- 1,315
This engine is on a Toro Proline 30159. It's the model with the electric clutch that runs directly off the charging system, no battery.
Does anyone know what the input voltage and output voltage for the regulator/rectifier should be? At full throttle, I'm getting about 48V AC in and 24-28V DC out. This is a brand new, genuine Kohler voltage regulator. Seems high to me, but I've never worked on one of these battery-less systems before.
Just trying to make sure the charging system is putting out the correct voltage so it won't fry the new $250 blade clutch I'm getting ready to install.
Thanks!
Thanks!
