Kohler CV 740 just converted from DSAM to MDI Ignition Coil. Tach doesn't work
pictaker247
  • / Kohler CV 740 just converted from DSAM to MDI Ignition Coil. Tach doesn't work
I have a Craftsman DGT 6000 with a Kohler CV 740 Command Pro 27HP. Just replaced the coils with the Kohler MDI Ignition Module Conversion Kit Part # 25 790 12. Runs great and smoother than before only issue is the tachometer no longer works. Any ideas?
Thanks
