Kohler Courage Help?
JonnyBlaze
Hi. Its been awhile. So I made a mistake. I had a good running Courage with a cracked block so I bought a good block on ebay and when I got the old one torn down I realized that tge provision for the counterbalancer stabilzer wasnt in the new block. What are my options? Look for the right block or buy the crankshaft from the seller I got the block from? What stabilizes it? Is there more to it? Am I missing something? See attached pics. Thanks.
Not sure if there was 2 or 3 variations in the counter balance systems
Nothing you can do with that block other than getting the crank & counterbalance that fits it
OR get your old block welded
Lots of people get away with nothing more than some aluminium putty or resi-weld .
If the crack is cleaned up really well, goos & goops seem to work
OTOH a weld will work better
Once it is patched a drop of blue locktite will fix the problem of vibrations loosening the top cover which is why the block cracked in the first place.
I have done some "temporary" fixes with Davcon over 5 years ago & the customer does not want to pay for the welding .
The Davcon is now weeping a little but the mower is working fine & customer is happy
JonnyBlaze
Thanks for the response. Im selling the mower Im putting this engine in so I want to do it right. What's different about the crankshaft? How does stabilize? Ill look for a crank on ebay but want to make sure I get everything I need and dont run into any other problems.
IT uses a different top plate with a track for the counter weight guide
In your circumstances I would take the case & top cover to a welder
It can be TIGed from the outside if you clean the case really well & the top plate needs to be there to clamp it nice & tight to prevent warping
Gas welding is better but not many weld Al with gas any more
JonnyBlaze
IT caqn be tiged from the outside if you clean the case really well & the top plate needs to be there to clamp it nice & tight to prevent warming
I figured as much. Thank you!
