I have a Cub Cadet 1045 with a Kohler Courage 20 on it that I cannot seem to get working. I was mowing grass a while ago and noticed I was burning oil, so I took a look and I had cracked block and a sheared off bolt on the head. I replaced the bolt and repaired the cracked block and put it all back together and could not get it to start. So far I have replaced the battery, the fuel filter, the spark plug, cleaned the carb, and I adjusted the head valves back into spec; and it still wont start...
One thing I have noticed is that the exhaust valve is popping. When I spin the flywheel and the exhaust valve depresses it gets to a point and then it pops back to its original location, not like a smooth motion at all. Im thinking that could be my problem. What would cause that?
Thanks in advance!
Thanks in advance!
