Hey!
I bought a used 2014 Troy-Bilt mower a few months ago and it has been leaking gas from the carb. The carburetor says "Walbro 3" on the side. As I mentioned in the title it is running a Kohler Courage 20 engine and I believe the model is an SV600. The SV470-SV620 service manual matches what I see.
The gas leak is coming out of the jet (insofar as I can tell) and ultimately out of the air inlet by the choke plate which makes me think that 2 things are going on:
1) The fuel shut off solenoid doesn't work (maybe)
2) The float valve isn't seating properly and gas continues to flow into the bowl.
I have a small rebuild kit that has all the gaskets needed for the carb, to include a new float valve needle. The float valve needle currently in the carburetor looks brand new - the guy I bought it from claims to have serviced the carb before selling it. The odd thing is that there doesn't appear to be any kind of a rubber gasket at the bottom of the float valve needle seat... The kit I bought has a small gasket that seems slightly too large for insertion into the seat though the rubber end of the float needle appears to be just the right size for it.
Additionally, if I insert the float valve needle directly into the seat as-is (with no gasket installed) the back of the needle is perfectly flush with the back of the seat; everything seems to play nice together. Still... the darn thing is leaking so I'm kind of at a loss. I'm tempted to spend the $150 to buy a new OEM carb for it but I think I might be close to getting it fixed... any advice would be most appreciated.
Can provide photos if that would be helpful
