Kohler Courage 19hp Twin Cam OHV Single Cylinder Too Tight
Freddie21
  • / Kohler Courage 19hp Twin Cam OHV Single Cylinder Too Tight
Got this garage find and engine was free when parked a year ago. Craftsman DVT4000 lawn tractor. Was seized when I got it. Small amount of Mystery Oil in cylinder over night freed it. Now it turns very hard (breaker bar on shaft bolt). Starter will not rotate it. Plug is out and belts are off. Where should I go next? Thanks
Pull the closure plate off the top & have a look inside
Kohler had a problem with some of thess plates as the front 4 bolts come loose.
Now that I thnk of it I have one that would not crank simply because one of these had backed out so far it fouled on the flywheel .
Freddie21
Bolts are tight...someone has been inside before. lots of red silicone. Thanks
Hammermechanicman
Got this garage find and engine was free when parked a year ago. YOU KNOW THIS FOR A FACT OR DID SOMEONE TELL YOU THAT? Craftsman DVT4000 lawn tractor. Was seized when I got it. Small amount of Mystery Oil in cylinder over night freed it. Now it turns very hard (breaker bar on shaft bolt). Starter will not rotate it. Plug is out and belts are off. Where should I go next? Thanks
Pull the heads offand check the cylinders. If they are good may have to disassemble engine to check rods on crankshaft
Freddie21
Thanks everyone...not wanting to rebuild at this time
