Kohler Command Pro Part ID
sshelby1
I have a Grasshopper mower 623T with a Kohler Command Pro engine. I am wondering if someone can tell me what this part is? It is on top of the engine and has a red connector with a green wire. Hopefully the pictures help. I had to make them small to get them to attach.
Oil pressure switch. If connected is supposed to shut the engine down if low pressure is discovered. Just don't rely on it shutting the engine down before damage occurs. Had a shut off pressure of something like 5 psi.
Some are wired to instead of shutting the engine down, turns on a low pressure warning light or in some cases is wired to a buzzer.
sshelby1
Thank you very much for the reply and part id!
