Generac and Stratton
- Sep 3, 2019
- 8
- 33
Engine is from 2002/2003 and in a late 90's Wheelhorse and is apparently a repower the previous owner did (bought at estate sale so no history but he changed fluids). Anyhow, it ran great for about 2 years, always fired right up. Then more recently, had some hard to restart when hot occurrences, and noticed the fuel filter was collapsing (see through) so replaced that. Then shortly after coil died. Replaced that. Now cranking w/o start. If I mist starting fluid, it'll run briefly. Do that a few more times and it'll start running on it's own and stay running. But let it set awhile and starting fluid is needed again to get it running.
Does this sound like a carb issue? Float sticking?
