My 1996 Lawn tractor with Kohler Command engine loses prime in the carburetor after sitting for one week. This has never occurred before now...I have to take the gas hose lose at the pump and add gas in the hose to fill the carb bowl...then it starts right away. I do not notice any leaks at the carb and the gas lines have been replace a couple of years ago. What I will do is give it a couple of days and pull the bowl to check if it is full. Any other ideas?
