I have an exmark with a kohler command and it will not start- just cranks
I have spark
I have fuel
I replaced the fuel filter, cleaned the plugs , and cleaned the carb.
it will start on starting fluid but dies as soon as you stop spraying it. I turned the key without cranking and can hear the click of the fuel solenoid.... I also took the hose of the fuel pump and verified it pumps fuel when cranked
any thoughts?
I have spark
I have fuel
any thoughts?
