I have a 2005 Exmark Lazer Z 60" with a 25 Kohler. I have been chasing a loss of power issue for the past couple weeks.
Compression is 130-135 on each cylinder
Replaced all fuel lines, filter, and pump
Replaced air filter
Plugs are clean
Cleaned carb
Replaced intake and exhaust manifold gaskets
All pulleys are rotating fine
Mower idles and throttles up fine but once you put any load on it, it bogs down.
Any thoughts or help would be greatly appreciated.
Replaced air filter
Plugs are clean
Cleaned carb
