Friend brought me a Toro w/ a 6.75 Kohler; bought it used. Starts on 1st pull & rpms are right at 3200. However, after about 30-40 seconds, the rpm's dip audibly by probably several hundred & black smoke (not thick black, but definitely visible) is emitted from the muffler. Then, after another 30 seconds it revs back up to where it should be & he is able mow his lawn. This is a new symptom for me; any ideas?
