Mower started missing on one cylinder. No spark on the plug. Looks like the ignition module (magneto)
Removed the magneto from the non-firing side to different Kohler engine and it worked fine.
Shutdown wires are clear to ground when key is ON, Shutdown wires are grounded when key is off.
I moved the magneto from the cylinder that was firing to the cylinder that was not, That cylinder now fires.
One magneto works fine and the other does not work on this engine, but will work on another engine.
Flywheel magnet seems fine, good pull on both magnetos.
At wits end! Comments Please!
