Kohler 13 commander swapped
Garyjr
Swapped kohler 13 commander with mechanical fuel pump with gravity wiring different...help please
Garyjr
Switched same motor just one is older
Exactly what do you want to know ?
Both motors should have the same wiring unless one had a powered timing trigger ( SAM ) .
So pull the blower housings off both engines, note where each wire went to on the old one , lable the wires on the mower side of the plug.
Then make sure the m=new engine wires from the same items goes to the same place in the plug a the old one did .
If you want any meaningful details then we need full model numbers and better still some photos .
Mechanical pumps or gravity fed or impulse pump makes no difference to the wiring .
