Kawasaki FH721
dean7777
Kawasaki FH 721 starts with starting fluid but dies quickly. New gas and fuel pump works. Any suggestions? Clean carb?
txmowman
Power to the solenoid on the float bowl? Hear or feel a click when ley is turned on?
dean7777
I will check the solenoid. Thank you very much for your help.
dean7777
it was the fuse, started right up. Now it's blowing oil out of the exhaust.
Thank you for your help!
boatmoter
are you adding any type of additive to the E10 fuel your running to curb the Ethanol?
