blaylockvol
- Aug 6, 2022
- 1
- 1
My mower is almost 20 years old and had to replace/repair the right side pump/motor and the ignition switch, brought it home and mowed a couple hrs. The 20 amp fuse blowed. I looked at my wiring diagram, there are 2 twenty amp fuses under the mower seat, the bad fuse was connected to 2 red wires, one going to the ignition switch and the other to starter solenoid. Took it to the shop, the mechanic said I had a couple of loose wires, I took it home and mowed all day no problems. The next day I got on it and when I engaged the pto, the mower died. Checked the fuse, it was blown. Replaced the fuse, the mower started right up, went to engaged, the mower died. I have read the comments below on the thread about the blown 15 amp fuse. Does anyone have. any thoughts on what is. causing the same fuse to blow? Bill
