Just got this 1994 Lawn Boy Gold Series Commercial Mower for $50 on Craiglist. It had all the attachments: Rear bagger, side discharge plate and easy mulch plate. Always wanted a Lawn Boy and I needed a smaller mower for some tight spots my tractor can't reach.
It started right up at the guys house but when I brought it home it only stayed running for a couple of minutes. So I cleaned the carb, cleaned the exhaust, muffler, got a new throttle spring, spark plug, recoil rope, Filter-Fuel screen (612974), ignition coil and new air filter. Cleaned up the deck and sprayed it Grabber Green while I was waiting for all the parts to come. Looks great and I am very happy it turned out. It is amazing how light weight these mowers are.
Now the problem.....I have to leave the choke on to keep it from stalling. If I move the throttle to run it stalls pretty quickly. I have adjusted the idle needle first from lock half a turn out then 2 turns out. Then I tried adjusting the Air Vane to speed up the engine then slow down the engine. I am using Lawn Boy Ashless oil mixed at 1:32. One can to 2 gallons. The guy had 5 can's left that he gave me. I was told I might have to reclean the carb. Hope that is all it was.
Here are a few pictures:
