John Deere Z950R Low Oil Pressure code 2-7
Conrad Roberts
Hi, I have a 2015 JD Z950R 72" that I recently bought with 815 hrs on it. The machine runs great for about 30 minutes and then it bogs down and shuts off and the warning code 2-7 comes up which indicates a low oil pressure issue.
I have replaced the oil and oil filter after reading another forum suggesting trying a different viscosity. I went from 10-30 to 20-50 with the same results. I have also replaced the oil sending unit and checked the connections but that made no difference either. There are no oil leaks so I'm at a loss for what to do next. Any advice would be greatly appreciated.
Check your oil pressure.
First monitor oil pressure while cranking If no oil present present stop cranking and find why. Also if the pressure is below 10 PSI stop the engine before damaging the engine.
Warm the engine for 5 minutes @medium idle speed to warm up the oil.
It should be 43-85 PSI @ 3200 rpms.
firejay0007
What was the find on the 950r problem that was throwing the code 2-7 low oil pressure and shutting off
