Hi
I have a John deere x300r with a 17hp kawasaki (kaxs family)
Engine runs fine for a few minutes and then starts spluttering.... I can only keep it going by feathering the choke in/out to get it back to the shed! Tractor only has 200hrs on it!
I've changed fuel and filter (twice), put sea foam though (twice), blown through the fuel lines, checked the fuel solenoid (clicks nicely with 12v), and sprayed copious amounts of carb cleaner through the carb.....
Presumably it's a bath for the carb next??
If I take the carb off, do I need to strip it before soaking or do I just soak it as is? Presumably I'll need a new gasket set afterwards?
Any other ideas?
Cheers
Any other ideas?
Cheers
