John Deere Suggestions
ronblick
Looking for sugggestions on a used JD four wheel drive heavy duty lawn tractor with belly mounted mower. Have two acres of hill side that I mow. currently using a JD 318. In need of something bigger that has four wheel drive. Love my 318 but just not quite as stable on the hills as I would like. Help
D
Deleted member 97405
Guest
If you don't want to step up to a compact tractor, I would look at the older X500 series or the newer X700 series. Deere has 4WD models in this lineup.
