James Odom
- Sep 20, 2020
- 1
- 1
I have a John Deere LX277 with a kawasaki engine in it and i can not get it to run.
This mower had sit in a shed for about 4 years before I got it. I cleaned the carb and fuel tank. It run good after this and was cutting the grass then it quit.
It has yellowed fuel so I assumed that the tank had lacquered gas that had came loose. I installed a new fuel tank, new fuel hose and filters and it will not start now.
I cleaned the carb again and removed all the jets and made sure they were all clean. The fuel pump it pumping fuel to the carb.
I spray starting fluid in to the carb and it will not start.
I changed the spark plugs and have fire to the them and the motor turns over very strong.
Any help would be appreciated
