John Deere LA105 Wiring Repairs
Breeze12
Does anyone know the wiring details of a John Deere La105 riding mover???
My dog(s) chewed ALL the exposed wiring to my JD- LA105 mower and although I know they sell wiring harness kits, it’s an older mower with a ton of hours on it. I was hoping to save a few bucks by splicing/connecting wires.
Is anyone out there good with this kind of thing? I’ve tried to match colors and such, but some wires appear to be combined/ it’s not as straight forward as it seems. - It doesn’t seem to be a 1-to-1 wire fitting.
please help!
The wires will go together 1 to 1 if they are chewed through between connectors
JD has a habit of changing them at each connector so say a pink wire can be pink on one side then pink + black on the other side then at the next connector go strait pink again.
JD only publishes their wiring diagrams in their technical manuals which are not cheap, but less than a replacement loom .
If you are on good terms with your local JD dealer he might print one off for you but you will need the full serial number off the ID tag for him to do it .
I do not have a LA manual sorry .
