The mower:
I am willing to answer any questions, provide any additional information, or take some pictures/videos as needed.
- John Deere L110
- Kohler 17.5hp (CV491s)
- Been sitting outside for 7-8 years
- Replaced battery, spark plug, and carburetor which had it was running and cutting
- The mower will not turn over now (a couple days after it was running and cutting)
- Replaced spindle assemblies and it won't turn over after putting the deck back together
- Replaced the air filter when replacing the spindle assemblies
- The starting solenoid seems to be good
- I have replaced the starter in an attempt to fix the issue to no avail
- I have also added some oil and it may be a hair on the full side
- When I turn the ignition, it attempts to turn over and even turns the flywheel about half a rotation on occasion before stopping. If I continue to turn the ignition, nothing happens.
- The flywheel is difficult to turn by hand and is rusty (just surface rust, no major pitting)
- When turning the flywheel by hand, I can hear some grinding/squealing
- If I remove the spark plug when turning the flywheel, I don't see any oil coming out of the hole
- I have a fuel pump and fuel filter on hand but I don't believe those are the issue
- There is some debris in the fuel tank
