John Deere L110 2006- having a problem with the engine shutting down when I try to cut in reverse. This model has a button that you depress when you want to cut in reverse. It has worked for years. I have bypassed the seat kill switch with a clamp to keep it engaged and that has worked for many years. It wouldn't stay in the seat pocket anymore, so I needed to pull it out and bypass it. Even in doing that, the reverse cut has worked correctly. Note: The engine will keep working when driving in reverse if the blades are NOT engaged.
This just started recently, and I am unsure what may be wrong. Any suggestions?
