blackhawk7
- Apr 24, 2021
- 1
- 1
My JD D-140 lawn tractor with about 200 hours struggles on modest hills, but the rear drive wheel is spinning. I am wondering if this has more to do with the tire traction rather than a problem with the much discussed threads about transmission problems. Is it possible that i just need to add wheel weights or weight in rear to get the traction the mower needs? It seems to run slightly better if I lean back on the seat so that is why the problem can be solved by adding weight to the rear wheels.
