John Deere 317
Dekel
Hi.
Can’t find oil filter in my lawn tractor 317 tractor.
It’s 20hp kohler
Any idea where is it.
Location of the filter may vary depending on model of the engine. And some engines don't have an oil filter. Get us the model of the engine and we can do more research.
D
Deleted member 97405
Guest
317, if it has an oil filter, would be located on the side of the engine. When you remove the side covers, you should see it. If you don't see a filter, then your tractor doesnt have one.
hlw49
Some of those engines had a remote oil filter with hoses running to it.
