Anyhow, on the ignition system, it depends on the 'age" of your engine. I believe that model uses a FC290V (if you can get the complete engine model # that will be very helpful, FC290V_ _ _ _)
Most consist of your Ignition Coil (sometimes called a magneto)
Flywheel which has the magnet to produce the current and of course the spark plug.
Now, most FC290's also have an Igniter,
Which is basically takes the place of points, and usually when they stop working, you have no spark at all (From my experience).
So since you've tried spraying in the fuel in the plug hole and you've got good spark, i think the next step is to remove the blower housing and check the flywheel key.
this video gives a good "general info" on the flywheel key.
you can see it's sheared in the video... now if the key is good it will make a perfect square in the slot.
