Hi Everone
I own a la 125 John Deere lawn tractor with 80 hrs on it? its burning oil and smoking Plus leaking oil from the fuel pump? I知 guessing its coming from the crankcase?. To much back pressure ???When the oil is topped it smokes really bad then when it burns the oil to half it hardly smokes I知 hoping it only the fuel pump ?lus how does the fuel pump run it has no wire or mechanical to run it ?I also did a compression test and it was 105 ..If anyone can help me with my problem that would be great
Thanks and have a great day
Cheers
Ed
Cheers
Ed
