JD RX75
jb4249
Does anyone have experience with JD RX75 rear engine mower. I am trying to find parts to repair the deck and can't find on Green Parts. Can't find on Amazon either, no surprise. I need to rebuild or replace the blade spindle and both pulleys. Any help would be appreciated with a source or proper part numbers.
Thanks, Ted in KY
D
Deleted member 97405
Guest
I work at a Deere dealership. The attached files should help you with part numbers for your mower deck. The spindle uses two bearings. Here are the part numbers. Note: AM121970 is a superceded part number.
  • dba7251d-47b2-4a13-8b41-39a3ddc847f3.pdf
  • 1e0d2c55-ab8d-4457-ba14-eb30f9d73bba.pdf
