JD L130
Johnny T
Got new clutch, came with harness, old clutch only had two prong flat plug, new harness plug is shaped like a L, I can remove plugs from flat one and install into new harness plug but not sure which goes in which hole, one is yellow other are two wires to one plug which are brown or black. thanks
I’d say you may have th wrong clutch. 99% of replacement clutches should plug right in. With a wiring diagram you should be able to wire that clutch in, but I would double check to see if you had the correct clutch first.
tom3
Later today I'll take a look at my mower and see how it's wired, if anything shows up that might help I'll post.
