JD 75 x gas in the oil
Dave9354
How is gasoline getting into the oil on my jd 75x lawnmower? What should I look for? It has a Kawasaki engine. Could a blown head gasket cause this?
Usual suspect is the float valve failing allowing fuel to overfill the carb then trickle down into the engine ( thank the EPA for that ) and end up diluting the oil.
Remove the carb and clean the float needle & seat ( may need replacing ) then fit an in line tap between the tank & the carb and turn the fuel off when finished mowing.
