Jacobsen super of 1880
Wetfit
Jacobsen super Lf 1880. Reels won’t engage. Mower will still die if you engage the switch when you’re not in the seat but will not en gage reels forward or back lap. Reels turn by hand. Everything lifts correctly and travels correctly
noname1208
I figured it would be easier to piggy back here and we might both get an answer
I've got an lf570 doing the very same thing. The safties still kill the engine if the deck is switched on and you get off the seat and the reels will still do the full lift and full drop only when the switch is engaged so it's not the main cutting switch.
I think we have the same issue Wetfit and I'll update here if I can find what is doing it
