hrdman2luv
- Aug 23, 2014
- 62
- 345
Before I get into this, let me just say, I understand the dangers in disabling safety switches. . So no need in explaining all that... I've been researching safety switch problems, and can't see to figure this one out...
It's a craftsman LT1000. 19.5 I/c.
Yesterday, while mowing, it sounded as if it was about to run out of gas. So I disengaged the mower deck and hurried back up to the house. After putting more fuel in it, It started trying to die on me when I released the clutch and also (while just sitting with the clutch/brake pressed, it would die if I engaged the mower deck..
Without thinking, I took off the safety switches from both the deck engagement clutch and the one that attaches to the frame (down by the starter solenoid) .. Both tested fine. So, I'm thinking it's the seat switch.. I removed the bottom cover (from under the seat that has the two thin springs (with the spacers), took out the two spacers and tightened the seat all the way til it bottomed out. Still does the same thing. So then, I used a jumper wire on the harness. And it still does the same thing. Tries to die when I either left off the clutch brake or engage the mower...
In checking the switches (the ones I took off first), I got .000 (and a beep) from one side without pressing the button. But had to press the button to get .000 (and a beep) on the other side. So, I'm thinking, those are good.
The seat safety switch, (which only has two wires) beeps now as well. (but I didn't test it before I removed the spacers and bottomed out the nuts)....
Any suggestions??????????
Update. Checked the seat switch, with everything back in place, and it was fine. Tried to start it, and it did, several times... Then it died on it's own.. So, I checked the spark.. And no spark.. The engine, Briggs 19.5 opposed twin, will turn over. But no spark.. Going to check the ground wire going to it's and the gap of the coil. It's a new coil. So hopefully, it's not that..
Put the other coil on. It cranks and runs. But still tries to die when I try to engage the mower or release the clutch/brake.
