Anyone familiar with starters for B&S Engines,
This is on a Troy Bilt Pony riding mower. The starter will not turn the engine over until the outside temp reaches 85-90 degrees. At tht point it usually starts and runs fine. I have tried adjusting the valve lash with no avail. I can turn the flywheel by hand through the compression so I don't believe that is the problem. The started was removed and tested and though it spins freely when power is applied it does not turn smoothly if turning it manually. It sort of bumps around like maybe a bearing problem. If I spin it by jumping it and hold it upright I can hearing what sounds like a slight grinding or whining noise. Could this starter be the problem? Thanks!
