Is a Simlicity Regent as reliable as John Deere?
mucksiegooma
I have a 19 year old John Deere LT 150 and want to upgrade to a new tractor. Is the Simplicity a better machine than a John Deere S240?
Chuter
I don't really have the answer to your question, but since no one else has chimed in, I'll give you my 2 cents worth. We probably need to update that expression.
My guess is that the two are about equal on reliability but have no real data to back that up. Neither is sold in the big box stores, so cost wasn't the primary factor in design. I would recommend you compare features on the two to be sure neither is missing something you really want, and if possible, take them out for a test mow. I bought a Regent about 12 years ago after 15 years with a Broadmoor that was already 10 - 15 years old when I bought it. The Regent served me well for the 2-3 years I had it (before moving to a push mower house), but I was surprised at how flexible the frame was both while mowing and blowing snow. If you went over a bump with one wheel, you could feel the frame twisting! If all else was equal, I would still buy the Regent over the Deere, just because I like the way it pulls the mower instead of carrying it.
I was in Quality and Reliability engineering and management for 30 years, in a couple of different industries, then spent the last two years before retirement (about the beginning of Covid) as the service writer for the lawn and garden section of our local John Deere dealer. My biggest learning while at the JD dealer is not to buy any of their products that start with a 1 or have an E in the model designation. They were clearly made of cheaper components (deck spindle bearings and transaxles come to mind) and lighter weight fabrications. The sales department's line was "It's the best $2000 tractor on the market, but it's still a $2000 tractor." They tried to sell customers up to the bigger tractors but wouldn't turn down a sale (by the way, you could get the same tractor from us or the big box store for the same price, but we delivered it free, and would pick it up once for warranty.)
Similarly, a lot of Simplicity dealers will try to sell you up to the Broadmoor to get the heavier components. Heavier frame and transaxle come to mind.
JD was very good on warranty, they call it bumper to bumper, excluding only wear items like belts. If the belt died as a result of some other component failing, the belt was covered too. Didn't matter at that time if the unit was purchased new or used, we could check the serial number and tell if it was covered. Simplicity doesn't cover anything except to the original purchaser.
I felt that the 300 series and up from JD were very good, well designed and well-built machines. I rarely saw a 200 series. I don't really know why we didn't sell many of them. When we did service one of them, or the older LT100 series for that matter, they seemed to be decent tractors. But I cringed whenever someone brought in a 100 series, telling me he (or she) expected typical John Deere quality, since it came from the same factory. Of course, I couldn't tell them that the factory it came from had less to do with reliability than the initial design. No matter how carefully and skillfully a product is manufactured and assembled with inferior and/or lighter weight components, it's not going to be the same. The other end of the shop saw similar issues with bigger tractors with an E in the model designation.
Personally, I'd recommend either a 300 series JD or a Broadmoor or up from Simplicity. But if you got 19 years from your LT, you probably took good care of it, and don't have too challenging of a yard.
I can't tell from your question if reliability is the primary or only deciding factor. If it is, I'd certainly go up to the larger size tractor, but get fewer fancy features (power steering, lift, suspension, etc.). These components by themselves are pretty reliable, but the more components you add to the product, they math says reliability will suffer by some amount.
Nice answer Chuter
Trying to get the " It is a disposable $ 2000 mower " through peoples thick skulls is really a hard job.
I always tell them to convert the price tag to hours worked to pay for it.
Then tell them my fathers 1962 petrol push mower is still running & being used to mow the common areas of 7 blocks of apartments .
It is still running because it cost him 6 weeks wages so how long do they expect a mower that cost less than a days wages to last .
Mucksigooma
Go sit in both of them
Ask for a test drive & if you can go over something rough even if it is just their driveway .
If you look after the mower it will last a long time so you want it to be comfortable so get them to adjust the seat to fit you properly.
Both are good machines
JD will be around till the end of time but Simplicity, being owned by B & S who look like they are going bust for the third time this decade might not be around in 10 year when you need parts or even worse be bought by MTD .
MParr
FYI: The John Deere comes with the no tools oil change feature.
This is something to consider. Many John Deere owners buy and install a conversion kit on these mowers.
7394
John Deere is sold in Lowes & Home Depot, plus I suspect other big box stores as well.. Haven't seen any Simplicitys' in any big box stores.
Neighbor has a Simplicity Zero 42" w/Briggs engine. That engine weeps oil from every possible place there is a gasket.. I know, I service it with him, started before it had 3 hours on it.. .
d2wing
I have a 05 Prestige that is still a great tractor. It did need head gaskets replaced once but other than that is trouble free. Same with my son's even older Broadmoor. Simplicity mowers are not big box mowers, but I would recommend a higher end model of either brand.
7394
I'd say Simplicity over JD.. fwiw..
bkeller500
Simplicity has a better deck IMHO. Depending on usage needs as long as you don't abuse it, you will be fine. The wear on the Regent will be similar to the S240 as they are both entry level models. To me it's all about the quality of the cut and Simplicity ranks higher on my list. Replace a few parts here and there and you will be fine.
