Mrd80
- May 14, 2022
- 1
- 1
Having issue mower will run about an hour starts surging. Then dies. Unless I release mow deck and push throttle to choke.
While sitting with it running for a few minutes but not driving it or engaging the deck It seems to catch its breath and keep running while I'm in choke.
At first I thought this was a fuel issue and I thought maybe that it was the fuel cut off solenoid in the bowl of the carburetor and expecting that it would heat up after time and fail but I replaced it and that did not solve the problem.
Now I'm starting to think it's a coil that's starting to overheat after a certain amount of time I did stop the mower for 20 minutes and it ran fine for a while but then started doing the same thing over again.
I took a video but unfortunately this site does not allow me to upload the video.
