I have an early 6.5 hp Intek engine on a walk behind. This looks like a Quantum but is OHV. It has trouble starting and when it does start it lets out a puff of smoke. Engine model 11A602-0151-E1 I have done the following:
Reset the magneto gap to .010
Cleaned the Carb and changed all intake gaskets
Change the spark plug with a new and set gap to .020
Using fresh fuel
Changed the primer bulb
Set valve lash to .005 on both intake and exhaust.
On a cold start it takes a minimum of 4 pulls to starts it Sometimes as many as 8.
On a hot start it can start right up with one pull.
When it starts it will let out a puff of smoke for a few seconds. I assume it is rich gas that did not fully burn. However I realize it could be a leaky valve seal. It runs good once started. No smoking or any issues.
I have not pulled the head to look at the cylinder wall or inspect the valve train. I am thinking that may be my next step but I wanted to post the problem before I dive in to that.
I do not have a leak down tester. Otherwise i would have tried that by now.
Any thoughts?
Using fresh fuel
Any thoughts?
