Hello, everyone.
I have a Craftsman with a Briggs Flathead engine Model 42E707. One of the intake valves is not fully opening. The valve is new and moves freely. The problem seems to be the valve lifter. When the valve is taken out, the tappet is loose and can be moved easily. When the valve is installed, the lifter only opens the valve by approximately 1/4". The other three valves are all working fine.
I am a novice with engines, so apologies if I am not explaining very well. I was wondering if it is a problem with the Tappet or a problem with the camshaft lobe. I appreciate any advice or opinions.
Ron
Ron
