l008com
- May 25, 2015
- 40
- 238
I know this is the "lawnmowerforum" but is it ok to talk about other power machines besides lawn mowers?
If so, I want to upgrade the lighting on my snow blower. Like so many, it has that one incandescent light bulb that does almost nothing.
First, I need to know how much "free electricity" I have to work with. Given that the oem headlight is incandescent, if I even know it's wattage, I could probably find some LED lighting that is within that wattage, that is 10x brighter. There are lots of small 18W offroad LED lights that I think would work nice.
Also, is the OEM headlight 12v DC or 12v AC? If it's AC, i'd have to wire a rectifier inline too, right?
Also does that bulb have a name or number or type? If I'm going to do this mod, I think it makes sense to pop a weak LED in the OEM headlight slot anyway just so I have some light shining on the machine itself. If a rectifier is needed, and I put it inline behind both lights, then it should be fine I think.
Note: This blower does not have a battery. It's pull start or 120vAC start.
This is what the device has for an OEM headlight bulb: https://www.ereplacementparts.com/lamp-p-1303289.html?osCsid=i1sm6sb9jrc2o6to9jtvdjat87
