Injector Pump
cambre
I have an older model Kubota L35 tractor that I cleaned filter bowl and I cannot find where to bleed air out of the injector pump. Any help would be appreciated. I should say how to bleed fuel system.
You may have to bleed it old school. Meaning that you loosen the injection lines and crank until fuel comes out of the lines. Just don't crank to the point that is overheats the starter. may have to due it in stages.
cambre
Thanks ILENGINE, I will try that.
