I picked up an older Powr Kraft 18HP/42” mower. The info. Sticker/plate is missing.
Looks like it’s a Montgomery Ward Power Kraft Lawn Tractor (1994) engine info
Briggs & Stratton engine manufactured CODE # 9404015A / April 01 1994.
I’m looking for some information on-
1. Size of front tires & rim size & diameter of axle-(tires don’t seem right air valve & zerk/grease fitting face inside, center of rim is offset a little bit) Any replacement suggestions/manufactures& part numbers?
2. Throttle control box ass’y seems to come down from fast to slow when in use. Control box (top & bottom cracked a little) & choke ass’y (missing retainer)easily comes out of dash. Any suggested fixes for?
3. Hydrostatic transmission maintenance
How to check fluid level?
Should You change fluid & how often?
What kind of fluid?
4. Any suggestions for DIY Grass collector bags?
THANK YOU for any suggestions & help
What kind of fluid?
