SeniorCitizen
- Aug 28, 2010
- 123
- 2,108
Does this site have an ignore to click on ? If so could someone direct me to the spot to click on ?
I believe to ignore, you just scroll on bye or don't click at all, or.........you could just stay in bed all day!Does this site have an ignore to click on ? If so could someone direct me to the spot to click on ?
If you want to ignore a poster than you can hover over the name under their picture and the window that opens has a button for ignore.Does this site have an ignore to click on ? If so could someone direct me to the spot to click on ?
Your don't actualy click the avatar, you simply hover over..Yeah what ILENGINE said..
Just click on the persons avatar. Then you will see an ignore button.
Depends if you allowing the lawnmowerforum.com script to run or not. Running it is hover over or click on, not running it is click on.Your don't actualy click the avatar, you simply hover over..
Yeah I'm using a tablet so you "touch" the icon.Your don't actualy click the avatar, you simply hover over..
