John@86143
- Aug 16, 2020
- 1
- 3
I'm new to this forum. I have a Gravely Pro 20G with a 20hp engine. I bought it used about 20 years ago. It has been an wonderful machine. I have ran into a problem. I cannot start the engine with the ignition switch. I bought a new switch and it worked for awhile, but now it is doing the same thing. I have checked and tightened the battery wires, tightened the solenoid wires. I can jump the battery wire from the solenoid to the wire to the starter and with the key on the engine starts. I have sprayed the wires that connect to the ignition with electrical wire cleaner, no help. I am at a loss at what to do next. Any help would be appreciated. I apologize for not following the sign in new members. I was on a kindle and over looked the introduction part.
