ignition coil for model#10604
rushblvd
I need the ignition coil for Lawnboy Model 10604 -20 Mulching /Rear bagger ....I don't know which one to order??? Help:confused2:
Can't tell you unless you post your Kohler engine model number. I'm guessing you will need part number 14 584 16 if you have a cast iron flywheel. Or, part number 14 584 05 if you have an aluminum flywheel. Your engine numbers will confirm which.
