I have a Weed Eater WE-ONE 26-Inch 190cc Briggs & Stratton 875 Series mower that was given to me not long ago. I have been trying to get it running and I got it running good today. I started cutting grass and hit some long grass it bogged out and died. Now I can't seem to get it started again. It's getting fuel I can smell it but its not getting fire. So I pulled the ignition coil off and tested it on 20k ohm settings on my meter. It's showing 4.70-4.88 ohm setting. I know 2-5 ohms is suppose to be good but this one is pushing 5. Does that mean its the coil that is the problem? I can't see anything else that it might be when it was running great then just died and won't start again. I set the gap between the coil and the flywheel the thickness of a business card. Is there anything else I can try to pin point this problem?
