ID this Swisher please
Went to fix this 60" Parklander in yesterday .
Assumed it would be a rebanded World Lawn from China like most of their stuff but is apparently a rebranded Swisher.
Unfortunately the rebadging including scrubbing out the original Swisher details from the ID tag & apparently Parklander could not afford to make one for themselves.
So can any one ID it please.
I need to get the IPL from the Swisher web page but I have to pick from 220 and that is way beyond my monthly data limit.
Bert, I am going to take an educated guess and say it is this model ZT2560
filename 11849_Rev_06-046pdf
If you type ZT2560 into the manual search there will be two models show up with the model number. Look for the 06 revision.
Tar,
Two or three downloaded manuals are fine, they just go into the library but 220 is just a bit too much.
And not particularly impressed with the machine.
I assume the Swishers are a budget mower for hardwear chains to sell.
Never knew they made anything other than the drag behinds.
So yet another learning process.
Plot thickens & spoils.
The decal under the deck specifies an A83 belt part No 10263
When cross refferenced I get these conflicting results
Gates 6811BR A 84.25 ( usually Gates right )
VBelts4Less A 83
Stens B 82
The old belt was a Pix A 82 (Aust ) A 84 USA size
Anyone actually know the belt size
According to the Gates web site Swisher 10263 fits the ZT / 2350 / 2450A / 2454 / 2450 / 2560 / 2660B
PS looks like Ilengine got the ID spot on, thanks greatly.
Unfortunately the downloads are missing most of the illustrations but I might be able to sort things out.
FWIW, the left front deck stabilizer bar support fell off taking the front height cable & pulley with it
I went back and checked the manual for the mower I sent the link on and for me it showed all the parts illustrations.
Downloaded the same file . + a few more
Diagrams are missing from ;-
P 24 , P 25 , P26 , P27 , P 28 ( 1/2 ) , P 30 , P 32 & P33
Transferred the files to "her" windoze box and wadda yer know, all of the line drawings popped up so looks like they made the book using Microsloth publisher.
This is one of those filthy monopoly ploys where regardless of it being a PDF it can only be opened properly on a Windoze box because Microsloths perverted PDF format uses the Windoze tool box.
It is probably not backwards compatiable to earlier version of Windoze either.
The genuine Adobe Acrobat application sent an error box saying it had unresolvable code which is what twigged the Microsloth only as I have run across this before.
So thanks again, printed out hard copies so I gon't have to pinch her box again ( I get into trouble for doing that ).
